Discussion topic: whn recording and try to change channels it shows up technical fault and screen is blank
This message was authored by: ARemac
Message posted on 31 Jul 2025 10:36 PM
cant watch other programms when recording as all channels come up technical fault and screen is blank
Find out more
Message posted on 01 Aug 2025 01:14 AM - last edited: 01 Aug 2025 01:15 AM
Re: whn recording and try to change channels it shows up technical fault and screen is blank
@ARemac Your post has been moved from the accessibility board as your issue has nothing do with Sky Accessibility.
You don't say which TV service you have, is it Sky Q or Sky Stream?
