Discussion topic: eARC not working, no volume on tv
This message was authored by: Rich2720
Set up my new Denon speaker, selected eARC setting in sound. No sound coming out of TV speakers when selecting eARC.
Re: eARC not working, no volume on tv
You have posted in the SKY GO forum, this is not the correct place for you to get help
Please answer the following question so that your thread can be moved to the correct place, where you're more likely to get help with your query
Which Sky TV Service do you have?
Sky Plus (Satellite box)
Sky Q (Satellite box)
Sky Glass (Internet TV)
Sky Stream (Internet box)
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
That's correct. If you use eARC then all audio is sent to the external sound device you have the other end of the HDMI cable attached to. The TV speakers will be muted. Depending on your TV there might be a setting to allow the TV speakers to have audio too, but there can often be syncing issues resulting in a very echoey sound.
