Discussion topic: Tv remote won’t stay paired
This message was authored by: bethanfletcher
Suddenly my remote unpaired from Samsung tv Tuesday night. Repaired it thankfully today but it instantly unpaired again. Sounds silly but I can't control volume or turn my tv off unless I unplug it. Proving annoying. Works sky fine.
Re: Tv remote won’t stay paired
You don't need to unplug your TV, all TVs come with their own remote control, you don't have to use the Sky remote for your TV
On my LG TV I use the TVs remote to control my Sky box
Try programming you remote with code 999 to reset it and/or remove the batteries for a few minutes
I am Neurodivergent Sky+HD  LG NanoCell TV  Xbox Series X  Raspberry Pi 5 (Debian Linux)
My F•A•Qs: Sky GlassSky StreamSky GoSky Plus
Avatar for bethanfletcher
Well funnily enough my actual tv remote has also stopped working despite putting in new batteries. Couldn't make it up so it's stressing me out now not knowing what is happening.
Are you 100% sure the issue is not the TV itself as two remotes have magically stopped working
Tv seems fine sky seems fine my apps via sky all work thankfully but just can't turn tv off or volume down or work tv parts. But yeah definitely strange. I'm just at a loss.
