		Discussion topic: Technical fault
	This message was authored by: Llandysul
		Message posted on 22 May 2025 05:54 PM
							Technical fault
						Why is there a technical fault on the one channel I watch a lot, sky mix, how can I fix it or is it's sky's fault
Find out more
		Message posted on 22 May 2025 05:57 PM - last edited: 22 May 2025 06:04 PM
							Re: Technical fault
If you have Sky Q try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Find out more
							Re: Technical fault
@Llandysul You posted this in the accessibility forum, however your issue is unrelated to Skys accessibility services.
We would also need to know which TV service this is on, Sky+HD, Sky Q or Sky stream/Glass
