3
This discussion topic has been answered Discussion topic: Sky radio channels and the remote control.
This message was authored by: TowerForte
You cannot add radio stations to your favourites why?
You cannot use the remote control to open BBC Radio 4 0104 sky glass will not accept four digit code why?
No use asking sky to go to radio four because sky opens BBC sounds which is not acceptable to a visually impaired person with voice guidance so you're stuck.
You can scroll down and find radio and sound I'm going there and find radio four but that is long winded why can't you just type the code 0104.
Please update it.
TF
Re: Sky radio channels and the remote control.
@TowerForte
As we are customers here, the team at Sky to contact about this are the Viewer Relations team and you can do so via this email address as they will reply to you  -  viewerR@sky.uk
@TowerForte
Avatar for TowerForte
Thanks, I have done that
TF
on Sky Glass and Sky Stream, radio stations are accessed via apps rather than EPG numbers, there are no 4 digit codes like 0104 to access specific stations.
