Discussion topic: Sky TV says there is a technical fault and to try again later
This message was authored by: PJ46
Message posted on 01 Dec 2025 07:02 PM
Can anyone help me get my TV back on? Thanks
Find out more
Message posted on 01 Dec 2025 07:10 PM
Re: Sky TV says there is a technical fault and to try again later
You have posted in the Sky Go forum though your issue does not sound like it is with Sky Go 😞
Please answer the following question so that your thread can be moved to the correct place, where you're more likely to get help with your query
Which Sky TV Service do you have?
- Sky+ (Satellite box)
- Sky Q (Satellite box)
- Sky Glass (Internet TV)
- Sky Stream (Internet box)
