Discussion topic: No satellite signal
This message was authored by: jacqui1957
No satellite signal
Can't watch itv
Re: No satellite signal
@jacqui1957
What box do you have?
Is it just on itv?
This message was authored by: Margaret42
No satellite signal since 8.30pm approx last night
This message was authored by: Damex29
  • The notice on tv states "problem with your satellite signal.
@Damex29
If you have Sky Q, and a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
