14
Discussion topic: How to connect smart tv to sky hd box
This message was authored by Psingh36 This message was authored by: Psingh36
I have bought a smart tv but I don’t know how to connect it to my sky+ box?
will sky provide me with a new box that has a hdmi cable?
I currently only have the skart cable or is there any other way?
This message was authored by caesarome This message was authored by: caesarome Answer
Re: How to connect smart tv to sky hd box
You can purchase a hdmi cable from online retailers like Amazon, ebay etcor from high street shops,
Locked
This message was authored by Annie+UK This message was authored by: Annie+UK
Contact sky, you might have to upgrade to Sky Q
I'm guessing they have not got a Sky+HD box but just a normal sky+ box so they have no HDMI output to plug the cable into
Psingh36
yes thank you i will do that
Psingh36
@Annie+UK
sorry forgot to specify I've got a sky+hd box.
This message was authored by goldsmith2805 This message was authored by: goldsmith2805
Did you manage to connect your smart tv to a sky he box. I'm thinking of getting a smart tv, but have no idea how to connect it to my sky had box. I'm not very tech savvy and some of the answers are confusing to me. Thanks
All modern TVs have HDMI sockets, if your Sky box does not also have an HDMI socket then you'll either need some type of converter or a secondhand Sky+HD box (models DRX890 or DRX895)
My sky box is sky had, so I guess it has an hdmi port.
Yes, my sky box is DRX890
Yes, my sky box is DRX890 so has an hdmi port
This message was authored by Mark39 This message was authored by: Mark39
Re: Yes, my sky box is DRX890
Easy, then. You just need to connect an HDMI cable from your Sky box's HDMI socket to one of your TV's HDMI sockets. No tuning or anything required.
When you want to watch Sky, just turn on your Sky box and your TV might automatically switch the input to the HDMI port. If it doesn't use your TV remote's input button (it might be labelled source or AV rather than input).
Connect smart tv to sky hd box
Great, that sounds simple. Only thing is, my remote doesn't have any buttons labelled source or AV.
Re: Connect smart tv to sky hd box
This is your TV remote?
Ok great. I've got it. Thank you so much. I said I wasn't very tech savvy. You must think I'm stupid. Once again, thank you so much. I truly appreciate your help. 👍
This message was authored by Norty This message was authored by: Norty
I have now connected sky to my new smart tv but the screen keeps going off and then comes back on after about a minute with apps showing at bottom.
When i go into SOURCE it is saying that the HDMI port is UNKNOWN.
Locked
