18 Dec 2023 11:38 AM
My old TV died so I installed a replacement which used to be linked in another room. The TV works but I cannot access Sky channels. Do I need to go to a specific channel or use a code?
18 Dec 2023 11:43 AM
Posted by a Superuser, not a Sky employee. Find out more18 Dec 2023 02:08 PM
Posted by a Superuser, not a Sky employee. Find out more@Sportnut I'm guessing the new TV is connected via coax cable and a magic eye to your Sky+ box in another room. If that's right, you'll need to use your TV's setup menu to carry out a channel scan in order to pick up your Sky box.
Couple of points:
1. Does your new TV have an analogue tuner as well as DVB-T/Freeview/Digital? If it doesn't have an analogue tuner, it's not compatible with your Sky box connection
2. If your Sky box's RF Output Channel is set to the default channel 68, your new TV may not find it, as new TV's won't tune above channel 50.
On average, new discussions are replied to by our users within 5 hours
