Discussion topic: Sky talk phone accepts incoming but can't dial out, cuts off after dialling.
This message was authored by: madmal
Started last night, 18/9/24, we were alerted that we could not be contacted by phone.  This morning , 19/9/24, allows incoming but cannot dial out, cuts out after dialling.
Re: Sky talk phone accepts incoming but can't dial out, cuts off after dialling.
See if you can run this line test to see if a fault is found outside of your property and if something is found you can book an engineer repair, ignore the fact it says it will test your broadband:
https://www.sky.com/help/home/sky-talk/fix-problems-with-my-phone/articles/fix-phone-problems-start
You can also run this test via the MySky app.
Let us know how you get on.
