Discussion topic: Sky talk - landline not registering incoming calls
Message posted on 08 Jul 2022 05:09 PM
When ringing my landline it does not ring the actual phone & just rings out on the phone u call from , any help would be much appreciated. Thanks
Message posted on 08 Jul 2022 05:12 PM
Re: Sky talk - landline not registering incoming calls
@SKY3CBEC Is you phone connected to the correct point?
Does you hub have a voice light? If yes, is the phone plugged into the back of the hub?
Message posted on 08 Jul 2022 05:17 PM
Yes phone plugged in and voice light on
Message posted on 08 Jul 2022 05:20 PM
@SKY3CBEC Are you able to call out? If so what number displays on your mobile for example? Does it match the one you should have?
