Discussion topic: Phone plugged in and has dual tone BUT WHEN CALLED DONT RING AND GORS TO VOICEMAIL
This message was authored by: Mr+peed+off
Message posted on 03 Jan 2023 01:25 PM
Phone is plugged in and has dial tone. WHEN CALLED DONT RING AND GOES TO VOICEMAIL
Find out more
Message posted on 03 Jan 2023 01:40 PM
Re: Phone plugged in and has dual tone BUT WHEN CALLED DONT RING AND GORS TO VOICEMAIL
Looks like you have a fault that you'll need to report to Sky. Try the connection test here, regardless of whether or not your broadband is working ok. If a fault is detected you may be able to book an engineer there and then. If not and you are still able to make calls give sky a ring to report it on 150.
https://www.sky.com/help/home/sky-talk/fix-problems-with-my-phone/articles/fix-phone-problems-start
