49
This discussion topic has been answered Discussion topic: New fiber broadband and now landline doesn't accept incoming calls on my landliaccept incoming calls
Avatar for Glenpaul1
Level 2 icon
This message was authored by: Glenpaul1
Re: What cordless landline phones are people using
Spoiler
@GD1  Hi, thanks for the reply, the landline is plugged directly into the max hub and nowhere else this hub doesn't use the lead with the purple plugs
Level 2 icon
@Mark39  Hi Mark, the max hub only uses the phone lead nothing else, I went through this with sky yesterday and they said it was correct.
@Glenpaul1  I think we may be at crossed purposes here, the issue isn't the handsets, there is definately an issue with your line (not how or where it's plugged into) and Sky need to investigate this as you've tried different handsets with the same result.
Level 2 icon
Re: New fiber broadband and now landline doesn't accept incoming calls on my landliaccept incoming c
@GD1  Hi mate, thanks for the reply, looking like I'm going to be bending their ear again, to be honest when I spoke with sky I did get the impression that I was being fobbed off, the phone worked perfectly fine before I let them put this junk in my property, when all said and done if a phone works OK one way there is no excuse for it not to work the other.
This message was authored by: Dave+r55
I've had the same issue for 9 days sky have been no help at all.
Have sky sorted it, I keep being told its a outage problem, but the family next door Have no problem.
Re: Landline unable to receive incoming calls since Sky broadband activated
I've got the same issue called sky 6 times, no advice they keep fobbing me off with its a outage problem,
What issue, exactly? What's the background? Are you new to Sky? Or upgraded recently?
Level 2 icon
@Dave+r55, Hi Dave, did you get the feeling that you were getting fobbed off, spoke to sky on Saturday, put me on hold while he tried to call me on landline, no luck, so that's when he was laying the blame on my phone, whats wrong with sending an engineer to come out and test the phone port, he soon disappeared leaving me to set the phone up saying it'll take a couple of days to sort itself out mate, yeah whatever, apparently all the other broadband providers are having the same issue..
Hi thanks for getting back, I e had this problem for 9 day I've called them 6 times with no success its like there reading from a script, had your been sorted and how was it sorted, I'm at my witts end and you can't get a straight answer of them.
Level 2 icon
@Dave+r55 Hi mate, not doing too well are we, I'm going to ring them again, and to make matters worse my wife is doing her nut, especially after we've just been out and bought a new phone, sky will still want their money though.
Same here, the problem is her mother doesn't have a mobile and relies on a land line to keep in touch, we are at our Witt's end trying to get this sorted,it's like I'm talking to the cat.can I ask where you live,I'm in Pontefract.
Level 2 icon
@Dave+r55, Sorry mate I don't think we are supposed to give out info like that
Level 2 icon
@Dave+r55, I've been reading loads of stuff tonight, alot of it related to a problem with the phone number porting
Hi , do tell because I've given sky till tomorrow afternoon to give or fix this issue. I'm fed up with being fobbed Off with its a outage problem , hope you get yours sorted.cheers
Answered - Go to Answer
