Discussion topic: Need to get my phone fixed and the only way to reach Sky is by phone
Message posted on 03 Nov 2024 12:33 PM
Message posted on 03 Nov 2024 01:00 PM
Re: Need to get my phone fixed and the only way to reach Sky is by phone
There is no 0800 number and Sky don't use email for general communication or fault reporting. As you're asking about an 0800 number I presume you have a mobile so
you can call Sky free by dialling 150 from a Sky Mobile. Alternatively you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and a 0333 number is displayed.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a dedicated 0818 ROI number.
(The forum doesn’t allow us to type the numbers in full).
Message posted on 03 Nov 2024 01:28 PM
I have a non-Sky mobile, so that doesn't particularly help, tbh
Message posted on 03 Nov 2024 01:32 PM
@MB123 some background please. Does your phone have a dial tone? Is it a corded phone? Has your Sky landline phone worked ok up to now?
Message posted on 03 Nov 2024 01:35 PM
Thank you. No dial tone at all, my phone is cordless. It has been working for several years (mainly to receive nuisance calls, ha ha), so this is new. I unplugged the double socket and plugged my phone in direct to the phone socket, but still no better.
Message posted on 03 Nov 2024 01:44 PM
That's helpful. Does your wall socket have separate ports for broadband and phone, or just the one port?
If it's one, is your phone base station plugged in via a microfilter?
Do you have access to a corded phone to rule out a fault with your cordless setup?
(These are most likely checks Sky would ask you to carry out)
Can you try the simple connection test here, even if your broadband is working ok (they're delivered via the same cable)? Let us know the result.
Message posted on 03 Nov 2024 01:55 PM
My answers below:
Does your wall socket have separate ports for broadband and phone, or just the one port? Separate ports
If it's one, is your phone base station plugged in via a microfilter? N/a
Do you have access to a corded phone to rule out a fault with your cordless setup? No. I had a cordless phone which I thought may be the problem, so I bought another new cordless one and am having the same issue. Would that change with a corded one?
Can you try the simple connection test here, even if your broadband is working ok (they're delivered via the same cable)? Let us know the result. Done, and everything seems to be working fine
Message posted on 03 Nov 2024 02:03 PM
Perfect. As you'll have difficulty calling to report it, I'm guessing you'll be happy for us to ask Sky's messaging team to contact you here, so that you can report it via a private online chat.
I've alerted them so you should a blue/red chat 'bubble' towards the bottom of the page and receive an invitation to chat later this afternoon/evening. Just click on the bubble to initate the chat. Replies from Sky may not be instant, so check back from time to time for updates. Once the chat is activated it remains open for 48 hours, after which it will automatically close..
For the detail of how it works see this guide: https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Message posted on 03 Nov 2024 02:06 PM
Thanks so much!
Message posted on 03 Nov 2024 02:08 PM
Thanks for escalating this. We’ve sent @MB123 an invite to chat.
Message posted on 03 Nov 2024 02:09 PM
By the way, while you're waiting for Sky, have you thought about using the free Sky Talk Shield to stop unwanted calls?
Message posted on 10 Jan 2025 12:52 PM
Having this same problem, and I thought it was just me, seems like it is pretty widespread, my landline has not worked for months, been away, but I am sure I am missing calls, hospital appointments and the like!!
Message posted on 10 Jan 2025 12:56 PM
Hi there Billlee1 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Lisa - Sky Tech Team Expert
Message posted on 18 Jan 2025 03:50 PM
Thank you. Still working on it!
