Discussion topic: Lots of crackling and noise in landline
This message was authored by: Johnstonr
Our landline is very crackly and there's lots of noise making it almost impossible to hear anyone. Any hints please?
Re: Lots of crackling and noise in landline
Are you able to call Sky on the 150 number so they can run checks on your line ?
@Johnstonr you could try the simple connection test here even if your broadband is working normally (they're both delivered by the same cable). If the test detects a fault, you'll be able to book an engineer there and then. Otherwise give Sky a call, if you can, as @caesarome posted.
