Discussion topic: Landline will not accept incoming calls after full fibre insulation
Message posted on 29 Apr 2026 01:36 PM
After full fibre insulation landline will not accept incoming calls
Message posted on 29 Apr 2026 01:54 PM
Re: Landline will not accept incoming calls after full fibre insulation
@Rogeco55 I assume you can make calls ok. When was your full fibre service activated? Did you have Sky Broadband before full fibre was installed? Do you have a white Max broadband Hub, or a black one?
Message posted on 29 Apr 2026 02:05 PM
Had full fibre installed 1 week ago, already had sky broadband installed, but since upgrading will not accept incoming calls. Can make outgoing calls.
Message posted on 29 Apr 2026 02:10 PM
@Rogeco55 try switching both your broadband Hub and the fibre ONT off at the plug for 30 minutes. If you have a white Hub, switch them both off for an hour.
If that doesn't resolve it, it may simply be that it's taking a little longer than normal to switch your landline service over, but it's probably worth reporting to Sky. We can ask Sky's messaging team to contact you here so that you can report it via a private online chat, if you wish.
