2
This discussion topic has been answered Discussion topic: Has anyone put a phone doubler in the back of their Sky Wifi max hub
This message was authored by: SteveLP
Just wondering if they'll actually fit or if I need to get one with a short wire.
Avatar for SteveLP
Level 4 icon
This message was authored by: SteveLP Answer
Re: Has anyone put a phone doubler in the back of their Sky Wifi max hub
Thanks , I got a cheap one as above without the short lead and fits fine, was worried about the orientation in case it was vertical cos of the shape. But fits in the slot fine and easy to get in and out. Obviously covers the FTC and other style phone inputs but neither of which are in use for me.
@SteveLP  You are better getting the one with the short cable. I used to one without the cable and it was not good trying to get it back out the port when I no longer needed it.
Avatar for SteveLP
Level 4 icon
