Discussion topic: Do i need a phone like with fibre op
Message posted on 11 Aug 2023 02:18 PM
Do I need a phone for fibre op broadband
Message posted on 11 Aug 2023 02:22 PM
							Re: Do i need a phone like with fibre op
No as the fibre line will carry any voice service provided by Sky, with Sky you plu your phone into the hub, there is no need for a seperate phone line.
Message posted on 11 Aug 2023 02:23 PM
If you have a handset already it should work fine. If not you just need a standard (not VOIP) phone handset. Bear in mind your phone has to be plugged into the Sky Hub, not the wall socket, so you may find a cordless DECT phone useful.
Message posted on 11 Aug 2023 03:09 PM
We never use the phone so maybe I should get rid of that expense
Message posted on 11 Aug 2023 03:27 PM
Make sure you're on the Pay as you Talk package which has no monthly subscription. You only pay for the calls you make, so no calls, no charge.
Message posted on 12 Aug 2023 08:57 AM - last edited: 12 Aug 2023 09:02 AM
As @Mark39 indicates, on the default service there is no expense associated with voice calling if no voice calls are made. The concept of 'phone line rental' is essentially obsolete in the modern world: paying for a digital data bearer (i.e. a wholesale FTTC or FTTP link) at the address is part of the broadband subscription and is required for terrestrial internet access.
