13
This discussion topic has been answered Discussion topic: Connecting my Bt phone to receive calls
This message was authored by: Malseyepad
I have Bt wireless phones and they will not connect to sky talk
This message was authored by: Mark39 Answer
Re: Connecting my Bt phone to receive calls
@Malseyepad it may help if you can tell us if your Sky Broadband Hub has a 'Voice' light alongside the other lights on the front, and if it's lit. And if it IS lit, what colour the light is - amber or green.
What's the background to this, please? New to Sky? Worked before? Do you have Sky VOIP?
Avatar for Malseyepad
We had Bt digital phones, provided by Bt. We have moved everything to sky broadband, sky talk and my mobile, all working fine except for our phones, we are pensioners and am not really good with technology, so we are not sure where to put the phones. Do we need to get new phones, or will the Bt phones connect to the sky. I phoned Bt but they did not help me, just said not sure if the phones would work. Thank you all
This message was authored by: Lisa-P1987
Do you know if you are on VOIP or normal calls? That would make a difference in where your phone needs to be plugged in.
And are your services all active with Sky?
Lisa - Sky Tech Team Expert
thank you all for your advice and patience, we have found out that the phones we have are not compatible , so we off to buy new ones.
rnefards Marilyn
Sorry you've got to buy new phones @Malseyepad . Just for our future reference, do you happen to know if, when ypu were with BT, you had their Digital Voice service?
@Mark39  Yes we did have the Bt digital phones, which would not connect to our new provider,
we however brought a set of phones, and they connected immediately we plugged them into the sky box. Bt we're not very helpful when I called them, it took 2 calls to be told we could not use the Bt phones we had, supplied by them. Regards Marilyn
Glad you're working ok now @Malseyepad . Thank you for the information.
This message was authored by: G-Bizzle
Hello @Malseyepad I am having this exact same issue right now. Could I please ask what phones you used to solve the issue?
Kindest regards.
@G-Bizzle any standard phone should be fine. A cordless phone might be a suitable alternative, just not one designed to work with BT's digital voice service. Panasonic have a good range.
@Mark39 thanks for the info.
This message was authored by: Purpleteen
Hi,  I have a similar question. I have just bought a BT phone which sits on a base unit. The base unit has a connector cable which would normally go into the wall socket.
Is it THAT lead that goes into the Sky Q box and the phone will work as usual, ie charging on it's base then using the phone wirelessly? Or do I need a different type of phone that has a lead directly from the phone itself that goes into the sky box? It's not clear how I set it up.
I do have Sky pay as you talk, VOIP set up on my account.
@Purpleteen yes, you use the same connector cable that you would have previously plugged unto the wall socket. Just plug it into the Hub instead.
