4
This discussion topic has been answered Discussion topic: Connect phones to the hub
This message was authored by: John3570
  • Hi we've just gone over to sky broadband on Friday but can't get our phones to connect ... our phones only plug into a socket there's nothing on the base to plug into the hub anyone had the same problem. Thanks 🙏
Re: Connect phones to the hub
@John3570
As @cymru123 indicates, if you've switched from BT Broadband and this is BT 'Digital Voice' branded hardware then they aren't going to function with broadband from any other ISP: that's a design choice made by BT themselves.
If your base station previously plugged into a wall socket, just use the same cable to plug into the Hub.
Avatar for John3570
I've not got a base they are just on pods and you plug them in the wall
This message was authored by: cymru123
@John3570
What are the make and model of the phones you have? Are these handsets BT Digital Voice phones by any chance? If so they only work with BT's hub.
@John3570
