Discussion topic: Can't port phone number from Sky
Message posted on 30 Jun 2022 10:35 AM
Re: Can't port phone number from Sky
Hi, I read this thread because I was having having a similar problem with TalkTalk saying they could not port my old number from SKY. I just wanted to give my story because I managed to sort it without going through all the hassle DOCDEF had to (downgrading to a non-voip service). I thought this might be useful for anyone else in the same situation...
I completed the online order process with TalkTalk and I think I had to fill in my existing number and address etc, but at no point did it explicitly ask me if I wanted to port my number. (I assumed that maybe it would do it automatically if you didnt specify). On one of the last steps it said something about a new number and I was given a choice of timeslots for an engineer visit to install the new line. I thought this was odd but proceeded with the order because I assumed I could ring up TalkTalk, explain that I wanted to keep my existing line and all would be fine... How wrong I was!!
So I rang TalkTalk and told them the above story and that I wanted to keep my existing line. The lady on the phone ran a check on my line and said "unfortunatley Sir we are unable to port your existing number", so I asked "why?" She said she didnt know but that it would be fine and an engineer would be out to install me a new line and I explained I didnt want to lose my number because ive had it for 15 years and that I had ported it before 2 or 3 times and didnt want the hassle.
I persisted with the "why?" questioning. She went away for a few minutes and came back with "its because the line has already been disconnected". I said "well thats odd because im talking to you on it right now!"... She went away again for 5 minutes and came back with "Its because you have ported it too many times". I said "that is utter rubbish, you dont know and you are just trying to get me to agree so I accept the new line". After much persuassion she went away again and came back with "I dont know why we cant port it but maybe SKY are blocking it, so you better speak to them". I politley told her I doubted it but that I would check with SKY.
Before I rang SKY I tried to think why I would not be able to move and after a bit of googling came across this forum article. I thought the SKY VOIP service issue was plausible (I work in IT and have seen far less cause major problems!). I Explained the whole thing to a guy at SKY and also referenced this article. The guy at SKY was very helpful. He checked and there had been no request from TalkTalk to take over the line (they can see this apparently). He said that he didnt think the issue of switching from VOIP to analogue was a problem as otherwise they would be in massive trouble with Ofcom and would have lots of complaints from customers trying to do the same. He assured me there was nothing at SKY end blocking it and suggested that maybe becuase the order had already been placed for a new line, TalkTalk were just simply not able to switch it to a takeover order. He suggested ringing TalkTalk, cancelling the existing order and asking them to place a new takeover order; but do it over the phone instead of through the website. So I did just that.
I wont bore you with what a pain in the backside that has been but after speaking to about 5 or 6 people at TalkTalk in multiple departments I managed to cancel the order and place a new one. I was not able to place the new order until the cancellation was processed. I was told this would take no more than 24 hours. I got the cancellation email 4 days later. Long story short I now have the new order and have received confirmation from SKY that TalkTalk had requested a line takeover.
I wanted to post because this article is a bit of a red herring or an isolated case or this has been solved since the DOCDEF had their issue (24/01/2022).
I hope I dont live to regret going with TalkTalk as their customer service was abysmal, but the deal was too good to ignore!
Fingers crossed that I have no more issues, but if I do then I will post an update. (assume if no update, no more issues).
Hope this is useful to anyone in the same predicament. 😊
Message posted on 30 Jun 2022 02:13 PM
@TGEAM thank you for taking the trouble to post your experience.
I admit to being slightly sceptical that this will result in your number being ported successfully to TalkTalk, but that's my nature! 🙂 🤞
It would be great to know how it turns out in the end, if you have the time to let us know.
Message posted on 30 Jun 2022 02:51 PM
The reason talktalk can't port the number is due to the copper landline being deactivated. If Talktalk do a new order then openreach will charge for a new line to be installed (reconnected), which i believe is around £70. Talk talk will then bill you for this amount! Risk of losing your landline number as your number drops into open pool of numbers between your sky end date and the point openreach connect your line. (may only be a few hours gap but risk is there)
Message posted on 30 Jun 2022 02:53 PM
Of course, this is assuming talktalk do not have a voip system in place, in which case they should be able to port your number. happy days 🙂
Message posted on 30 Jun 2022 03:12 PM
@immy999123 wrote:
The reason talktalk can't port the number is due to the copper landline being deactivated. If Talktalk do a new order then openreach will charge for a new line to be installed (reconnected)....
Yes, that's kinda my take on it, too. I'm struggling to see how a line takeover and the porting of an existing number can take place when the presence of an existing Sky copper-based service can't be detected
Message posted on 07 Apr 2023 05:55 PM
I have read the posts carefully. the answer is straight forward. If you cancel the sky contract, you will lose the landline number but, if you contact anew provider first and ask them to request a port of the landline number, sky will allow the transfer of the number without question as long as you are still using the landline number and have not already cancelled the sky contract. If you check ofcom regulations, you will see that your landline number belongs to you until you cacel it. It does not belong to any telcoms provider. to recap. don't cancel you sky contract. contact your new preferred rpovider an say you wish to order a new service from them but they need to approach sky to port your number. Simples.....
Message posted on 07 Apr 2023 07:43 PM
Yes, that much is true. However I believe there are still complications if trying to port a Sky VOIP line.
Message posted on 07 Apr 2023 09:33 PM
@Mark39 Never had any issues in doing that. I just changed providers and moved from Sky VOIP to my new provider and my phone number came without any issues.
Message posted on 07 Apr 2023 09:51 PM
@Highlinder good to hear....
Message posted on 07 Apr 2023 10:01 PM
@Mark39 It was one of the things I was wondering on the activation date. It did take around about 16 hours for the phone to properly work. But that was a little more than when I moved from BT to Sky and found found myself with VOIP calls.
