Discussion topic: Can make phone calls but not receive them (Sky broadband hub)
Message posted on 12 Feb 2023 05:13 PM
Hi, I have connected my existing telephone to the Sky broadband hub into the phone U.K. port then connected one end of the black cable provided into the Sky hub (purple coloured plug into purple coloured socket of the hub) and the other end in white into the wall socket ( left side of a Mastersocket 5C Openreach Mk4).
I can make calls but not receive them, any idea on what needs being done?
Thanks in advance for your support!
Message posted on 12 Feb 2023 07:54 PM
Re: Can make phone calls but not receive them (Sky broadband hub)
@Legio What colour is the voice light if it is on at all?
Message posted on 13 Feb 2023 11:09 AM
The "Voice" light, along with all others on the hub is green.
Message posted on 13 Feb 2023 11:12 AM
@Legio Have you re-started the router since the installation of that router? If you have then sounds like an issue that Openreach would have to look into. This can be done by calling Sky on your landline dial 150, they maybe able to find the fault and book the engineer for you.
