Discussion topic: not getting a satellite signal
Message posted on 27 Aug 2025 03:09 PM
Not getting satellite signal.
Free33esdgteewwesaaguu
Message posted on 27 Aug 2025 03:11 PM
Re: not getting a satellite signal
No idea what the last two lines of your post mean.
The cause of the no satellite signal message is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
Message posted on 27 Aug 2025 03:13 PM
