Discussion topic: no signal to lounge sky box,ok upstairs.
This message was authored by: richo3
Hi,
Coming back of hoilday we found the downstairs sky+ box not getting a signal,the box upstairs works fine,i switched the boxes over and its due tothe signal.My contact switched over while i was away and iam thinking that sky switched of my multiroom,any one else had this issue?
Re: no signal to lounge sky box,ok upstairs.
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
@richo3 wrote:
Hi,
Have you checked your past present and future bills in mysky to check your subscriptions?
@richo3 wrote:
Hi,
Even if they had, you'd still get a signal to the downstairs box. It would just say you need to upgrade if you tried to watch a channel that's not free to air. It's most likely a dish/cable issue as @Annie+UK posted.
