10
This discussion topic has been answered Discussion topic: i cancelled HD TODAY , WHAT PROGRAMS WILL I LOSE
This message was authored by: Loismae
today i renewed my sky account , i cancelled HD to save money , will i lose programmes ,,,, ?
0r will i be able to watch them but not in HD
This message was authored by: nigea99 Answer
Re: i cancelled HD TODAY , WHAT PROGRAMS WILL I LOSE
Hi @Loismae
You don't loose any channels - as you suspect you will be able to watch  the  SD versions.
Any recordings you have made from the HD channels won't, however, be watchable
BTW A few channels (e.g. BBC) do not need the HD add on to watch in HD so these will still be available
You will lose any recording that come from subscription HD channels
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
You'll lose access to any programme in HD unless there's an SD variant. You'll also lose access to any recording from an HD channel
The exception to both of the above is any free to air channel such as BBC1 HD, which you'll still be able.e to watch and record.
There may be SD variants of the HD channels which you can watch and record instead.
Hi @Loismae
Avatar for Loismae
Level 2 icon
Re: i cancelled HD TODAY , WHAT PROGRAMS WILL I LOSE and will i still be able to watch sky sports
i've cancelled HD TODAY , will i be able to watch sky sports channelss they all seem to be in HD
@Loismae  You should be able to watch sky sports unless you have cancelled the sky sports hd subscription (if this was showing as a separate line on your bill), doing so will cancel sky sports completely has you can't have one without the other
@Loismae
SKY Sports are not covered by the standard HD add on.
In the UK all SKY Sports are in HD and not available in SD any more - as @SKY1992bf  there is a separate entry on bills for SKY Sports HD which cannot be added or removed independently to the SKY Sports pack
Edit : BTW SKY Sports Mix & SKY Sports News are not part of the SKY Sports pack and so having cancelled the standard HD add on you can only watch those in SD
Avatar for Loismae
Level 2 icon
Thankyou so much for clearing that up . i really appreciate it .
This message was authored by: Jubby1
So would you still get HD on normal tv channels but not sky channels if you cancel hd
@Jubby1
HD free-to-air channels remain viewable.
Whether those are 'normal' is somewhat subjective: personally I have grave doubts about most of the content on Channel 5 ; )
hi @Jubby1
You get the Free to Air Channels such as BBC & ITV in HD without the HD add on
There is a quirk that you can watch & record Channel 4 & Channel 5 in HD but you cannot download  from catch-up/On demand & watch in HD from these 2 channels
