15
This discussion topic has been answered Discussion topic: how do I stop message re losing sky programmes unless I phone keep appearing on my sky channels.
This message was authored by: juliebsb
I keep hetting the message 'you will lose Sky channels so phone this number' I presume this is to do ith sd channels going and I have an old Amstrad box but I refuse to change. I want to stop the message keep coming on the screen as it's very annoying, how can I do that?
This message was authored by: Mark39 Answer
Re: how do I stop message re losing sky programmes unless I phone keep appearing on my sky channels.
@Generalzod69 wrote:
I'm getting that message now on a Sky Plus HD box
You're probably tuned to one of the affected SD channels. Look for the HD variant. The message isn't displayed there,
You can't stop the message from appearing, but if you have a non-HD box and refuse the free upgrade to a newer box you will start losing channels, so you will need to arrange some other way to watch TV.
Avatar for juliebsb
Thank you for that. I don't want th upgrade as I use a DVR recorder and know I won't be able to use that with Sky Q. Until I find out which Sky channels I will lose, I will keep my old box. Someone has suggested to getting a 2nd hand Sky + hd box which maybe an option. I'd justlike to stop having to press back up to get rid of the message!
@juliebsb group don't necessarily have to upgrade to Sky Q, if that's a concern, you can buy a used Sky+HD box cheaply from ebay etc which will continue to receive these channels.
Edited: I see our posts have crossed and you're on the case!
Avatar for juliebsb
Thank you yes, someone has mentioned that!
This message was authored by: Generalzod69
Thank you
Avatar for juliebsb
Well, after following advice from some and buying a 2nd hand Sky+ box to enable me to continue to use my existing DVR machine, I have now received a letter from Sky saying that I will lose all Sky channels unless I upgrade to Sky Q from Sky+. Diabolical, I'm tempted to tell them where to shove their SkyQ but hubby loves his sports channels. Can anything be done or is this really the end of Sky+ ?
It's the end of Sky+ SD only boxes and earlier, Sky+HD will still work for time being
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
The advice was to buy a Sky+HD box. If that's what you bought, you'll be fine, as @Annie+UK posted.
Avatar for juliebsb
I hope you're right! As Sky just put Sky+ box on the letter and didn't specify SD or HD I took it they meant ALL Sky+ boxes. I know I'm a dinosaur still using a DVR box to record my programmes but I don't want to change and it seems. Sky may be forcing me to!!
The predecessor of the Sky+HD box was the Sky+ box.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
The link on the letter should clear it up for you @juliebsb :
https://www.sky.com/help/articles/sky-channel-upgrade
This means if you have an SD box, you'll need to upgrade to continue watching Sky channels.
You now have a HD+ box so you are fine.
