Discussion topic: dog chewed up sky remote control, how do I use my tv without this control
This message was authored by: JasonP11
please can you tell me how to use my tv without a sky remote control, its a Samsung
Re: dog chewed up sky remote control, how do I use my tv without this control
Use the tv remote?
Avatar for JasonP11
Level 0 icon
I have tried, which buttons do I push to just use a samsung TV remote control, can you be more specific please.  Step by step guide, thankyou
Purchase a new remote online or at a highstreet shop
In the mean time use the buttons on the Sky box
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Ah - you're aking how you control your Sky box without a Sky remote,  not your tv! You would have to use the physical buttons on the box, as @Annie+UK posted.
@JasonP11  You post is bit confusing, is it your Sky remote that is damaged and it is your Sky box that you need to control?  If so plenty of Sky+HD remotes can be bought online.
If you're asking how do you use the TV remote to control a Sky+HD box then as far a s I'm aware you can't programme a standard Samsung remote to give you full control of your Sky+HD box.  It will only control your TV, however if you have the much smaller Smart Remote you may be able to orogramme it to control some aspects of the SKy +HD box, you'll need to read the TV user manual as it will vary from Model to Model.
