Discussion topic: Your sky+hd box isn’t getting a satellite signal
Message posted on 12 May 2025 08:45 PM
Your Sky+HD box isn't getting satellite signal
Message posted on 12 May 2025 08:51 PM
Re: Your sky+hd box isn’t getting a satellite signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
