Discussion topic: Your sky + box not getting signal
This message was authored by: Mag+W
My sky+ box not getting a signal. We can't get channel 410 to watch sport
Re: Your sky + box not getting signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@Mag+W
Channel 410 is TNT and appears to be one of the first channels to be affected through a no satellite signal message (on Sky Q as well).
