Discussion topic: Wiring from dish to Sky + box
Message posted on 04 Dec 2025 09:38 AM
The wire from my dish has accidently been cut by a hedge trimmer!!! I tried to fix by rejoining the cables and initially system worked again.
Over the past month reception has been interrmittent with error signal appearing on TV on more and more occasions. Help please.
Message posted on 04 Dec 2025 09:41 AM
Re: Wiring from dish to Sky + box
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass, Sky Stream and Sky Q (Satellite TV is approaching end of life so is not a long term solution)
You will either need to replace thew cable yourself or employ a 3rd party to do the work as Sky no longer support Sky+ hardware
