Discussion topic: Will Sky replace SKY+ box in order to view BBCHD?
Message posted on 19 Aug 2023 06:24 PM
Hi All,
I've read Sky will replace my old Sky+ box for free, for a HD capable box, so that I can view BBC HD when the BBC service, from SD to HD, is upgraded soon. Do I have to be a Sky subscriber to be given this free box?
Thank you
Message posted on 19 Aug 2023 06:46 PM
Re: Will Sky replace SKY+ box in order to view BBCHD?
@Tubbsup wrote:
Hi All,
Thank you
Yes, Sky are not a charity
Message posted on 19 Aug 2023 08:21 PM
@Tubbsup Sky will replace boxes with Sky Q ones which requires the sky essentials package as a minimum even to view FTA channels
Message posted on 19 Aug 2023 08:41 PM
@Tubbsup wrote:Hi All,
Thank you
You can buy used Sky+HD boxes from eBay for around £30. Be sure to get a DRX890 or DRX895 model as these are the most up-to-date.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 19 Aug 2023 08:43 PM
You can always buy a used Sky+HD box from ebay etc. BUT without a Sky subscription you may not be able to pair your Viewing Card with a replacement box which means the default local BBC channels might not be for your area.
Message posted on 19 Aug 2023 09:09 PM
This has been my first posting, and I want to make sure each responder gets a thanks from me.
Thank you Annie, Sky1992, oj01 and Mark.
Tubbsup.
