Discussion topic: Will I lose my standard BBC recordings when I switch to BBC
This message was authored by: Wendym1
When I switch to HD BBC will I lose any BBC recordings made in SD?
This message was authored by: SlenderRobert
Re: Will I lose my standard BBC recordings when I switch to BBC
The only way you'll lose recordings is if you physically change your Sky+ box. All your SD recordings are stored on the hard drive on your Sky+ box. If you have a really old box and need to upgrade to Sky+HD or Sky Q then the box will need to be changed. In this case you will lose your SD recordings.
Avatar for Wendym1
Level 0 icon
Thank you, I have a had box but record in SD
If you change your Sky+ box then yes the recordings will be lost.
