8
This discussion topic has been answered Discussion topic: What would I lose if I cancel Sky Sinature . I have a sky +hd box .
This message was authored by: Loismae
I have a sky+hd box and  have
sky sports complete pack
Sky sports HD
Sky HD
& Sky Signiture
i want to reduce my payments so if I cancel the signature what programs would I use . ?
and do I really need Sky HD
This message was authored by: Mark39 Answer
Re: What would I lose if I cancel Sky Sinature . I have a sky +hd box .
@Loismae if you cancel Sky Signature, you'll be completely cancelling SkyTV. You can't have Sky Sports without having the Signature package. You can cancel the HD add-on if you wish, but I doubt the savings will be much.
@Loismae
Sky Signature is the base subscription so is needed.
Sky sports HD
Sky HD
& Sky Signiture
Hi @Loismae
SKy Signature is the 'Base' subscription & is the minimum needed  & you must have it to have any other channels (except  the Free ones)
Only you can decide if you need SKY HD & can put up with watching Channels in SD only although it does not apply to SKY SPorts which is separate  (You can't remove SKY Sports HD in te UK as it is standard)
Sky sports HD
Sky HD
& Sky Signiture
Hi @Loismae
If you have a Sky+HD box then you are in the wrong forum.
If you do have a Q box then the cheapest package is Sky Essentials.
This will give just basic free to air channels.
https://www.sky.com/help/articles/tv-essentials.
See also following link
https://www.choose.co.uk/tv/sky/reviews/sky-tv-essentials/
Avatar for Loismae
Level 2 icon
i have a sky +box by choice as i don't like the glass or Q , my bill goes up to £87 including Broadband , in April so i'm looking to reduce the cost , but keeping the sky sports full package , not really bothered about HD, and i only need the free channels really , any advice before i contact Sky is appreciated.
This message was authored by: Durham1944
Surely this can't be right. If it is, we are at the mercy of a bunch of con men.
@Durham1944
Not sure what you mean, Sky Signature is the basic TV package that you can have so if you were to cancel it you would be left with the free channels only.
@Durham1944
What's can't be right?
