Discussion topic: We are currently experiencing issues with lack of signalk, weve tryied turnunig off for 30 seconds
This message was authored by: J25S
We are currently experiencing lack of signal, we have tried turning off for 30 seconds but this doesn't make a difference sometimes if we turn off and back on again it will work for awhile
Avatar for J25S
Level 0 icon
Re: We are currently experiencing issues with lack of signalk, weve tryied turnunig off for 30 secon
We have tried turning off for 30 seconds and back on to gain signal but nothing is working
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
