Discussion topic: Tv picture keeps pixilating & loses connection. Have to keep swiching it off at socket
This message was authored by: SarahBruce
Been happening for several months even in clear weather & switching it off at socket doesn't always solve the problem.
Re: Tv picture keeps pixilating & loses connection. Have to keep swiching it off at socket
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
Phone a local sat installer to check your LNB and its alignment😉
Sky support Sky+ SD or Sky+ HD anymore🙁
Most likely a problem with your dish- either an alignment issue, or the LNB (on the arm) is failing.
You would need an engineer to check but unfortunately Sky no longer support Sky+ installations unless you have Sky Protect. That means you'll need to look for a local satellite installer to take a look,.
The alternative is to upgrade to Sky Q and your dish will be checked at no additional cost as part of the installation.
