Discussion topic: Tv picture breaking up constantly due to no signal
This message was authored by: LJM4_
All of my TV channels are pixelating, picture breaking up constantly. Notice on screen lack of signal. I've tested signal and it's ok. I've turned tv off at wall many times, no better
Re: Tv picture breaking up constantly due to no signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
