1
This discussion topic has been answered Discussion topic: Trouble with satellite signal
This message was authored by: Taslima3
The Sky+HD box is not getting a satellite signal for a couple of days now weve tried turning it off and on and made sure nothing is blocking the signal however it is still not working. Please could you guide us on how to fic it or send someone out please to check it out.
This message was authored by: Annie+UK Answer
Re: Trouble with satellite signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
