26 Oct 2022 07:22 PM
Hello I have a SKY + box installed the Time on it is an Hour behind actual Time, Weird as also showing programs listed an hour Behind. I have tried to Re-Build twice, no Change. What Do I do call an engineer, is there a fault etc, I know there is a thing about unplugging at the mains and pressing back-up etc on the front of, Sam-Community Manager mentioned something about this, Should I just wait until it sorts itself out etc, please reply-advise, thanks.
26 Oct 2022 07:33 PM
Posted by a Superuser, not a Sky employee. Find out more@Toymaker215 You need to follow the instructions here, or wait until it updates itself
https://www.sky.com/help/articles/updating-sky-box-software-sky-plus-hd
26 Oct 2022 07:27 PM
Posted by a Superuser, not a Sky employee. Find out more@Toymaker215 Is you box on model number R024.092.11.00p?
if it isn't you'll need to do the back up thing to correct it
26 Oct 2022 07:30 PM
Hello my model Number is R024.092.10.00p The time an Hour Behind just installed, tried Rebuild Twice-did not correct, please Advise, thanks.
26 Oct 2022 08:04 PM
The Advice to Update with the Sky Back Up button worked-Great advice, Thanks MUCH Gratitude-Time Corrected now on Sky+. Thank You @SKY1992bf thanks.
On average, new discussions are replied to by our users within 100 minutes
