7
This discussion topic has been answered Discussion topic: There is a problem with your Hard Disk Drive Recordings, On Demand and other services are not availa
This message was authored by: FrazzledMum5
Any clues how to fix this error please ?
tried the usual switching on off removing card etc . Also tried to 'rebuild' but response is The Planner cannot be rebuilt in Diskless Mode
This message was authored by: Mark39 Answer
Re: There is a problem with your Hard Disk Drive Recordings, On Demand and other services are not av
You could try a full System Reset, from the same menu as you used for a Planner Rebuild. If you get the same 'diskless mode'  message, it indicates  that your Sky box's hard disk has failed. Unfortunately Sky won't repair and no longer allow Sky+ equipment to be replaced, so your options are to upgrade to Sky Q or Sky Stream.
See my Sky Plus FAQ and search for diskless
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Avatar for FrazzledMum5
Level 0 icon
Thank you . That is indeed the error I keep receiving
You could try replacing the HDD ... but that's not easy on DRX890 or DRX895 boxes🤔
This message was authored by: littleles_-
Already tried, same message
Already tried what exactly?
See the post marked as the Answer for your options.
