9
This discussion topic has been answered Discussion topic: Technika TV model X32/29G and Sky+HD box
This message was authored by: Minesa99
Help!!!!!  TV has broken.  Been given a Technika TV model X32/29G on loan but I cannot get any channels at all.  Have checked all connections etc.  The TV has built in Freeview, does this mean I can't view through my Sky+HD?  Many thanks.
This message was authored by: oj01 Answer
Re: Technika TV model X32/29G and Sky+HD box
Then it should simply be connected via a HDMI cable and you just need to select the correct HDMI source on the TV.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
If you are connecting to the Sky Box via a coax cable then the TV needs an analogue tuner (Freeview is digital)
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
Avatar for Minesa99
Thank you
Is this your main TV, connected directly to the Sky+HD box?
Avatar for Minesa99
Yes it is
I think it's quite possible such a set isn't capable of full HD, though
@Minesa99
Avatar for Minesa99
Thanks, TV is connected to the sky box via HDMI leads but when I switch the TV on it goes through a set up and it doesn't find any channels at all.  It says no signal.
Avatar for Minesa99
Thank you
That's attempting to tune into broadcast digital terrestrial television received through an aerial.
Your Sky box is on an HDMI input port, not a 'channel'
Typically there's an option to disable the tuning routine, accessed using the TV remote control.
