Discussion topic: Technical fault with Sky TV
This message was authored by: SimonRidout
Technical fault with SKY TV - Sky TV is not working
Re: Technical fault with Sky TV
You need to give a more detailed description of your issue as "Not working" does not give much to work with 😞
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
For example : do you have menu access? Does the fault appear on live tv? Or recordings? Both?
