7
This discussion topic has been answered Discussion topic: TV guide showing “no listings available”
This message was authored by: LM67
Help
when looking at the TV guide on my Sky+ box is shows details but when you scroll forward a couple of hours/next day it's showing "..no listings available",
Anyone any idea what's going on?
This message was authored by: Annie+UK Answer
Re: TV guide showing “no listings available”
Swap the two input cables around and see if that fixes it
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
What are your Signal Strengths/Qualities? Take a look at the link below:
See question Q11 in my Sky Plus F⋅A⋅Q for Signal Strengths/Qualities
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
Avatar for LM67
Hi,
Done all that, also disconnected from router and reconnected with no change
@LM67
You haven't answer the question about yoir signal strengths as this issue has nothing to do with the broadband connection to the box.
So what is the signal strengths????
Also your router has nothing to do with the TV Listing, they are sent via the satellite
Avatar for LM67
Hi,
that might be the isssue , the input 2 strength and quality are sitting at zero
Avatar for LM67
Thank you soooooo much, that's fixed the issue
