Discussion topic: Strong satellite signal but add channels says none
Message posted on 17 Dec 2024 09:47 PM
On my Sky HD+ box services I have two very strong signals and my line up is fine with excellent reception on all channels. However when I try to access my extra channels or add others I get message saying the box is not receiving a signal.
Message posted on 17 Dec 2024 09:59 PM
Re: Strong satellite signal but add channels says none
Can you clarify extra channels?
Message posted on 17 Dec 2024 10:06 PM - last edited: 17 Dec 2024 10:07 PM
The most likely explanation would be the appropriate manual tuning(s) have changed.
