Discussion topic: Sound keeps going out of sync
This message was authored by: mezo123
Re: Sound keeps going out of sync
we found that just pausing and restarting would usually bring it back in sync for maybe half hour or so
This message was authored by: Bungaycanary
Thank you for the various replies. Your efforts are much appreciated and all have been tried out but sadly without success.
We still have the issue and Sky are being as helpful as an ashtray on a motor bike. In terms of frequency it probably happens two or three times a week.
For some bizarre reason it always happens with 'Beyond Paradise' which is not good for family harmony as it's one of my wife's favourite programmes.
All programmes on which the problem occurs have been pre-recorded and are viewed on playback.
Onwards and upwards.
This message was authored by: Kevlar1
Hi,
What you need to do is -
Go to settings then picture & sound.
Now change from Auto to PCM.
This worked for me.
Best of luck
This message was authored by: Lisaj860
This worked for me, thank you. Tried all settings adjusting sound delay and inputs on tv but nothing until this. Thanks
This message was authored by: Tommy1959
Thanks it worked with this fix.
This message was authored by: NiceSwan
Where is that menu? I can't see that within setting? Thanks.
