Discussion topic: Skybox says no signal
This message was authored by: AndreaJC85
I have had no signal for 48hours now. Have turned off and on at the mains, it has made no difference. I cannot access any tv services at all.
Re: Skybox says no signal
"No Satellite Signal" usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out sky or a 3rd party satellite/aerial company
Note: If you have a communal dish then this is maintained by your landlord/building management and NOT sky
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
