05 Mar 2022 12:37 PM
Hi,
Can anyone kindly assist? I'm currently upon Sky HD but want to go into SkyQ. The only real issue is since I've been on Sky HD I've had a conservatory built which is directly under the dish. I need to k is if this original dish and RNB be ok to use for Sky Q OR do I need another dish / RNB and if so can sky install this over a conservatory ( conservatory roof is no glass but had a lean too roof spanning 5 Mtrs by 3 Mtr).
Any advice/ information would be greatly appreciated so that I can get transferred to Dky W asap
05 Mar 2022 12:47 PM
Posted by a Superuser, not a Sky employee. Find out more@TheBorisJohnson I doubt that Sky will risk trying to access a dish over a conservatory roof, they may have to install a new dish if there is a suitable place with line of site to the Satellites.
05 Mar 2022 05:29 PM
Posted by a Superuser, not a Sky employee. Find out more@TheBorisJohnson At the very minimum, the LNB needs changing when converting from Sky+ to Sky Q. As @GD1 indicates, it's unlikely that Sky will access the dish above a conservatory.
06 Mar 2022 05:02 PM
You should have moved the dish to an accessible wall before getting a conservatory, unless the conservatory has a slated or tiled roof that you can walk up.
If the roof is perspex etc then nobody will go to that effort
On average, new discussions are replied to by our users within 100 minutes
