Discussion topic: Sky viewing card needs paired to Sky+HD box
Message posted on 28 Jun 2025 02:42 PM
Message posted on 28 Jun 2025 02:44 PM
Re: Sky viewing card needs paired to Sky+HD box
@Gareth141 Is this the same box the card was paired too as at end October 2024
Message posted on 28 Jun 2025 02:45 PM
@Gareth141 wrote:Sky viewing card needs paired to Sky+HD box
If it's a new card or a new Sky+ HD box then you can no longer pair them. Sky discontinued support for Sky+ last year so all you can really do is switch to Sky Q.
Is this the same card with the same Sky+HD box that were paired together back in October 2024?
Message posted on 28 Jun 2025 02:47 PM
Yes it is
Message posted on 28 Jun 2025 02:50 PM
Why does it need pairing?
@Gareth141 then try performing a new install
