4
This discussion topic has been answered Discussion topic: Sky+ telephone connection to BT going digital
This message was authored by: Seve
I have 2 Sky+ boxes which connect to my BT landline ,which I understand is used when booking box office programs, will this stop working when my line is changed over to BT digital ,(today) and is there anything I can do to enable this (BT offer a free digital adapter to connect to phones not near the router)  ?
Re: Sky+ telephone connection to BT going digital
@Seve
The phone line and internet connection to your box as two different connections so you can unplug the phone connection as you will be able to continue to use the box via the router nternet connection.
@Seve
As long as you two boxes have a connect to the meter net which they will do if you download content from catchup or boxsets then they do not need to be connected to your landline.
Avatar for Seve
Yes , they are both connected to the internet via Ethernet. Cable so I can get catch up and  box sets but will Box Office still work  which I believe uses the telephone line ? (These are Sky + boxes)
Everything works via the Internet when the phoneline is not used
I have BT Digital here with our boxes connected via Ethernet and everything works as expected
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
@Seve
