Discussion topic: Sky signal and program there and then not
This message was authored by: LP
No no signal messages
have replaced HDMI cable
have tried a different HDMI input
no error messages of any kind
have cleaned SIM card
have rebooted the box!!
any more ideas!!!!
Re: Sky signal and program there and then not
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Avatar for LP
Sadly & unusually no "no satellite" messages.  I find those easier to resolve!!!
I've just swapped the tv for another one and so far it's happier!
we can't have sky Q / they've tried and glass Isn't possible either!
