Discussion topic: Sky reverts to freeview mid afternoon
This message was authored by: Jojojoanne
My sky+ reverts to freeviw mid channel in the afternoon. Is there a timer that selects this that I can switch off?
Re: Sky reverts to freeview mid afternoon
What do you mean "reverts to freeview", Sky+ does not have any feature that would do this
I am NeurodivergentMy Sky FAQs : Go Stream Glass Plus
This message was authored by: Jojojoanne60
Hello Annie, thanks for your post. Its my mums tv that changes mid channel without her touching the remote. I'm never here when it happens but when I turn tv on its on freeview not hdmi1
@Jojojoanne60  It's sounds like an issue with the TV rather than the Sky+ box
Ok thanks. Any ideas how to fix please?
@Jojojoanne try changing the hdmi cable as that itself could be faulty
Hello thanks. Well I went into timer on tv and it was set to "once" for something. Will see if that stops it. Otherwise will change cable.
Thanks will try that too.
